Douments map
Post here those questions, bug reports and suggestions for SoftMaker Office 2016 for Windows that do not fit in any of the application-specific subforums.
NicoK
Douments map
Post by NicoK » Tue Jun 20, 2017 9:21 pm
I remember that an earlier Softmaker version was able to prevent building a Softmaker submap under My Documents. Is it still possible, and how? I try to keep My Documents as clean as possible, only for real documents.
Thanks. Nico
Re: Douments map
Post by sven-l » Wed Jun 21, 2017 10:28 am
Yes, this is still possible. Create an empty text file called portable.txt in the program folder. SoftMaker Office will then "think" it is a USB installation and will then write all settings and templates directly in the program folder.
Re: Douments map
Post by martin-k » Wed Jun 21, 2017 10:32 am
However, this means you cannot install SoftMaker Office to c:\Program Files (x86) because that folder is protected against writing in Windows. Install to another folder on your hard disk or USB drive.
