Ruler Problems
This beta forum will be closed soon. Please post in the regular forum for SoftMaker Office 2016 for Windows.
BearPup
Ruler Problems
Post by BearPup » Mon Mar 23, 2015 7:23 pm
Rulers in TextMaker, both horizontal and vertical, do not stay visible when showing tables or indents. Switching back to a 'normal' paragraph restores the rulers. This is something that has to be fixed.
Re: Ruler Problems
Post by sven-l » Mon Mar 30, 2015 11:52 am
According to the TextMaker PDF manual page 85:
The
horizontal ruler
is found at the top of the document window. The margins and tab stops for the active paragraph or for all the paragraphs that might be selected at
a given moment are shown there
A table or table cell is handled as a separate paragraph and therefore has its own ruler.
BearPup
Re: Ruler Problems
Post by BearPup » Tue Mar 31, 2015 9:24 pm
Hi,
Thanks for responding; I apologize that my response has taken this long to send to you.
I get the horizontal ruler part, and as often as I use tables, I had simply never noticed the horizontal ruler at the top of the page had expanded and shrunk as my tables changed. However, the vertical ruler is, I think, different. Comparing 2012 to 2016, the vertical ruler behaves differently. In the 2012 version, the vertical ruler stays the full height, whereas in the 2016 version the vertical ruler switches back and forth between full length and the width of 1 cell.
Your suggestions?
Regards,
BearPup
Return to “General”
