Drop caps in beta - are these fixed in release version?
This beta forum will be closed soon. Please post in the regular forum for TextMaker 2016 for Windows.
Alan Hope
Postby Alan Hope » Fri May 22, 2015 8:27 am
From http://code.stephenmorley.org/html-and-css/creating-drop-caps/
Any chance of something like this in the drop-caps function?
A correctly formatted drop cap has four key features:
  • The drop cap should share a baseline with the last line beside it
  • The top of the drop cap should align with the tops of capital letters on the first line beside it
  • If the drop cap has serifs, they should fall outside the left margin; if the drop cap has a vertical stroke on the left side it should be aligned with the margin
  • Unless the drop cap is a single-letter word such as A or I, the first line of text beside it should have less indentation than the other lines, in order to indicate the continuation of the word
Jim-J
Re: Drop caps in beta - are these fixed in release version?
Postby Jim-J » Fri May 22, 2015 1:42 pm
Hello,
I referred you feature request to the developer team.
Thank you.
Jim J.
Return to “Beta: TextMaker 2016 for Windows”
Who is online
