Error in document summary
This beta forum will be closed soon. Please post in the regular forum for TextMaker 2016 for Windows.
firkin
Post by firkin » Sun May 10, 2015 4:33 am
Don't know what this means, but when I look at the Document Summary, there is a message saying 'Error getting document statistic' even though the document statistics seem to be displayed correctly. See attached PNG file.
Re: Error in document summary
Post by sven-l » Mon May 11, 2015 5:01 pm
Does that happen every time you call the statistics menu? Does it only happen with specific files? I could not reproduce that issue here and assume it could have something to do with your file.
firkin
Post by firkin » Thu May 14, 2015 4:34 am
File attached. It certainly isn't happening with all files.
CrashTestDummyDoc.tmd
(1.34 MiB) Downloaded 55 times
Post by sven-l » Fri May 15, 2015 8:52 am
Thank you! I will report that to our developer.
Post by sven-l » Fri Jun 19, 2015 1:55 pm
The problem has been solved and should not occur anymore with the final version.
Return to “Beta: TextMaker 2016 for Windows”
