Bug: file open display?
This beta forum will be closed soon. Please post in the regular forum for TextMaker 2016 for Windows.
seasidepb
Postby seasidepb » Mon Mar 23, 2015 1:28 pm
Think I've found another bug. If you switch off "use system file dialogues" in the "Appearance" menu you get what in my view is a nicer native file/open window. However, if you then switch to the Dark theme, the files within a folder don't display in the second window (screenshot attached), so you can't actually open anything. You can use the system file dialogues as normal with the Dark theme.
I'm using Win10 TP build 10041, which I know you're not officially supporting yet, but since it's a problem with the native dialogue I'm guessing it may not be OS related.
seasidepb
Re: Bug: file open display?
Postby seasidepb » Mon Mar 23, 2015 5:43 pm
Hah fixed in the new beta (today)! Thank you... dark theme is my preference on Android, and I like it here in Windows too.
Return to “Beta: TextMaker 2016 for Windows”
Who is online
