Problem with tables
Post your questions, bug reports and suggestions here for TextMaker HD for Android.
boki
Problem with tables
Post by boki » Sat Nov 14, 2015 2:22 am
When I open a file created in Word 2010, which has 55 pages of which first 5 contain text and others contain tables (1 table perage), Textmaker shows only 18 pages - first 5 (ones with text) shows fine, and remaining pages are shown with overlapping tables (several tables perpage).
The same problem is present in both Textmaker HD and Textmaker mobile.
Is there a plan to solve this? This prevents me from using the app.
Re: Problem with tables
Post by sven-l » Fri Nov 20, 2015 11:31 am
Could you please send us that file to forum(at)softmaker.de? We would need to see this issue here in order to find a solution. Thank you!
boki
Post by boki » Fri Nov 20, 2015 11:34 pm
I sent it.
Looking forward to your reply.
boki
Post by boki » Fri May 13, 2016 9:05 pm
This is still unresolved.
Care to give any feedback on the issue?
Post by sven-l » Tue May 17, 2016 9:05 am
A new Service Pack has been released. Could you please try again with this update? Thank you!
boki
Post by boki » Thu May 19, 2016 11:24 pm
I tried it, but the problem is not resolved, the situation is same as before.
I sent a file with same table structure by email to you, as you requested, you can try and see for yourself.
Return to “TextMaker HD”
