Common file browser for all 3 Softmaker office apps
Post here those questions, bug reports and suggestions for SoftMaker HD for Android that do not fit in any of the application-specific subforums.
leonbobcamp
Post by leonbobcamp » Tue Dec 05, 2017 7:16 pm
Hi, I use Cloud Storage, namely DropBox.
Since Softmaker Office HD does not support Ctrl-S on files opened with the Dropbox app, would it be possible to have a common File Open/Browser for all 3 apps? Ctrl-S works if you open DropBox files directly from the app, it is however a hassle to have to open PlanMaker to browse/open Excel files, Textmaker for Docs, Presentations for ppt, and so on; it would be useful to be able to browse and open all the file types from one location.
Thank you
Re: Common file browser for all 3 Softmaker office apps
Post by sven-l » Fri Dec 08, 2017 5:02 pm
I will refer that suggestion to the product management.
Return to “SoftMaker Office HD for Android (General)”
