dropbox android app
Post here those questions, bug reports and suggestions for SoftMaker HD for Android that do not fit in any of the application-specific subforums.
leonbobcamp
dropbox android app
Post by leonbobcamp » Mon Dec 04, 2017 7:21 pm
Hi, I use Softmaker HD in conjunction with the DropBox android app. I appreciate the fact that Dropbox android allows to mark files for offline use.
I use the Dropbox app to open files into Softmaker HD, and have to use the save as option (&choose Droplox cloud), since in this scenario ¨Save¨ does not work. Would it be possible to enable Save in this case? In other apps, it works fine and the Dropbox file gets updated.
Re: dropbox android app
Post by sven-l » Fri Dec 08, 2017 1:18 pm
The support of the Dropbox app is on the wish list for the future.
leonbobcamp
Post by leonbobcamp » Sat Dec 09, 2017 6:44 pm
Thanks, great news
Return to “SoftMaker Office HD for Android (General)”
