(Samsung DEX) Office resizable screen, it is possible?
Post here those questions, bug reports and suggestions for SoftMaker HD for Android that do not fit in any of the application-specific subforums.
pplu2
Post by pplu2 » Tue Oct 17, 2017 6:39 pm
Hi.
I wanted to ask if it would be possible to make office HD windows resizable for use on the Samsung DEX screen.
When you start the application with the smartphone connected to the base DEX, you can see in the monitor that has the dimension of a tablet screen, the size of the window can not be resized.
It would be great to be able to interact with the window frames to fit them on the monitor.
Just this suggestion, thanks.
Re: (Samsung DEX) Office resizable screen, it is possible?
Post by sven-l » Tue Nov 14, 2017 9:06 am
I will refer your suggestion to the product management.
jh72de
Post by jh72de » Mon Mar 19, 2018 4:18 pm
Any development?
Post by sven-l » Fri Mar 23, 2018 1:41 pm
No, there are no news on this.
Return to “SoftMaker Office HD for Android (General)”
