Close The Apps When We Close Our Files
Post here those questions, bug reports and suggestions for SoftMaker HD for Android that do not fit in any of the application-specific subforums.
AJ_
Post by AJ_ » Sun Jul 02, 2017 6:16 am
Please see attachment. Please remove this screen form all your apps. It is completely useless and has induced bugs the few times I have tried to use it. When we close our files the apps should just close instead of having to close this screen too. To make matters worse, there is no X in the top right corner to close it. If we want to open another file we can just do it while the app is still open. This screen serves no purpose whatsoever other than to annoy your users. Please remove ASAP.
By the way, I just discovered the File Manager in your apps. It's the bomb for quickly opening files. Kudos to you!
Re: Close The Apps When We Close Our Files
Post by sven-l » Thu Jul 06, 2017 4:25 pm
I will refer your suggestion to the product management.
AJ_
Post by AJ_ » Wed Jul 12, 2017 7:36 pm
Thank you!
Return to “SoftMaker Office HD for Android (General)”
