Suggestion
As the public beta test has finished, this forum will be closed soon. Please post to the full version's forums.
Skiprus
Suggestion
Post by Skiprus » Tue Nov 11, 2014 9:58 pm
It would be useful to set the default directory for saving documents. I use an inserted SD card and prefer to use that to save device memory. Having a saved directory would shorten time.
Overall, however, I really like the latest release.
Re: Suggestion
Post by martin-k » Wed Nov 12, 2014 8:45 am
The way it should work (and we have designed it) is that a document is always loaded/saved from the last folder the previous document was loaded/saved from/to.
Does it work differently for you?
Return to “General”
