PlanMaker dd-mm-yy date format option!
As the public beta test has finished, this forum will be closed soon. Please post to the full version's forums.
granelde
Post by granelde » Thu Aug 14, 2014 5:50 am
Device: Samsung Galaxy Note 2014 edition
OS :Android 4.3
Planmaker :
Firstly well done so nice to have an Office application that I can use finally !!
Copied and pasted a row which contains a date cell. Problem is that this has Converted from UK (dd-mm-yy) to US format (mm-dd-yy)
This in itself wouldn't have been a problem if the Uk format option was available in that style yet dd-mmm-yy Is available but this is not suitable for the spreadsheet.
Can this be resolved please?
Jim-J
Re: PlanMaker dd-mm-yy date format option!
Post by Jim-J » Thu Aug 14, 2014 4:16 pm
Hello,
to paste only the values there is "Paste Special". Unfortunately, there is a problem with the copying mode, so this doesn't work properly.
We hope it will be solved until the next beta release. Then you can check on this issue again.
Jim J.
granelde
Post by granelde » Thu Aug 14, 2014 9:57 pm
Great to hear you are aware of it.
Return to “General”
