selecting text in textmaker
As the public beta test has finished, this forum will be closed soon. Please post to the full version's forums.
granelde
Post by granelde » Wed Aug 13, 2014 10:53 am
Device: Samsung Galaxy Note 2014 edition
OS :Android 4.3
Textmaker :
So far the only thing I've found that might be worthy of mention is that I was not able to selectivly select text to copy and paste though this could be more of an issue with Android!
When pressing and holding onto the screen the result is, it is similar to the right click on windows, this seems quite logical but the Android function would normally be to select text. Can this option be integrated into the context menu I noticed that there is a select all option!
Re: selecting text in textmaker
Post by sven-l » Thu Aug 14, 2014 8:29 am
A double tap should select the whole word your are tapping at. Afterwards you can drag the arrows at both ends of the selection to select the desired text.
granelde
Post by granelde » Thu Aug 14, 2014 9:09 am
Brilliant, that works.
Thank you so much.
Seriously looking forward to the live roll out.
Been a long time waiting for a serious word processor tool!
Watch out Microsoft now there is a real alternative :)
Return to “General”
