Garbled icons and screens
As the public beta test has finished, this forum will be closed soon. Please post to the full version's forums.
cartd
Post by cartd » Wed Aug 13, 2014 4:17 am
On first time Textmaker startup, the toolbar icons for Copy, Paste, Undo and Redo were garbled. I was not able to re-create this, because after exiting the app and restarting the whole screen was garbled. Then after restarting the OS (cold restart) the document window displayed normal, but the screen part above and below were garbled. As soon as I touched the screen the toolbars and footer appeared. Both Planmaker and Presentations behave in a similar way. I have to touch the general work area before toolbars etc appear.
Textmaker Beta (rev 711.0811.fl)
Acer A3-A10 Android 4.2.2
Re: Garbled icons and screens
Post by sven-l » Wed Aug 13, 2014 11:47 am
Thank you for the info! I will refer that problem to our developers.
cartd
Post by cartd » Fri Aug 15, 2014 9:23 am
Today I had a total green screen at startup. Disappears when touching the screen.
Jim-J
Post by Jim-J » Fri Sep 05, 2014 1:34 pm
Hello,
With the next release it should be fixed. Please check on it again.
Thank you
Jim J.
cartd
Post by cartd » Sat Sep 13, 2014 11:05 pm
The problem has been solved in the current release.
Thank You
Return to “General”
