eM client major update failure
Post bug reports and suggestions for SoftMaker eM Client Professional 5 for Windows.
mcolantoni
Post by mcolantoni » Fri Jan 18, 2013 2:37 am
I launched eM client today.
It asked if I wanted to update.
The update downloaded, started to run then asked me to insert a CD. I had to cancel that, of course, and the update failed.
What gives?
Re: eM client major update failure
Post by sven-l » Fri Jan 18, 2013 11:56 am
We referred that problem to our developers and will inform you as soon as there is a solution.
Post by sven-l » Mon Jan 21, 2013 3:24 pm
Does the problem still exist? If yes, please proceed as follows:
1) Open the command line (Start=>Rund=>CMD and type following: msiexec /i path /lv* filename.log (e.g. "msiexec /i C:\Users\YOURNAME\Downloads\setup.msi /lv* eMClientInstall.log")
2) Wait until the installation is done/crashes and send us the log via Tools=>Settings=>Logging
Thank you!
mcolantoni
Post by mcolantoni » Mon Jan 21, 2013 9:48 pm
I have already established that the problem is that it tries to uninstall the old version after installing the new version. It looks for the v4 installer to do this. It cannot find one so it stops. I am then left with v4 and version 5 on my computer.
To overcome this, I uninstalled both versions, than installed v5.
It now works.
Return to “SoftMaker eM Client Professional 5 for Windows”
