pre-installation question
Help for TextMaker 2002 for Zaurus
engine
Post by engine » Sat Apr 21, 2007 1:03 pm
My trial version runs out soon, and I'll be ready to install my full licence.
Do I need to uninstall the trail version first, or will installing the full version just upgrade as necessary?
Also, can I install TextMaker on to my CF card or does it have to go in the main memory?
Niels Grundtvig Nielsen
You know what you're talking about ‒ I can help you say it
http://www.kbss27.be
Tobias-L
Re: pre-installation question
Post by Tobias-L » Mon Apr 23, 2007 8:59 am
engine wrote:Do I need to uninstall the trail version first, or will installing the full version just upgrade as necessary?
You don't have to uninstall the trial first, as the full version will overwrite the trial.
engine wrote:Also, can I install TextMaker on to my CF card or does it have to go in the main memory?
Currently the installer copies the files to your internal memory only.
Tobias Leißner
Return to “TextMaker 2002 for Zaurus”
