BY DESIGN? OR BY BUG??
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2012 for Linux that do not fit in any of the application-specific subforums.
SeaDevil
Post by SeaDevil » Tue Feb 05, 2013 7:05 pm
i just downloaded this software into LinuxMint 14 Xfce.
I opened all the programs, planmaker...etc. and the first thing i noticed was, the
difficulty in following the tree as there are NO NAMES by each directory.
If this is by design, It is absolutely a disgrace.
Am I the only one who has this problem?
the name for each directory will appear if you hover over it.
this needs work !
or does someone have a solution to this?
Re: BY DESIGN? OR BY BUG??
Post by martin-k » Tue Feb 05, 2013 7:31 pm
Could you please post a screenshot of what you are seeing?
SeaDevil
Post by SeaDevil » Wed Feb 06, 2013 12:32 am
ok, I took a screenshot picture.
In planmaker, i clicked on File Open...and this is what I get. I tried to type in a filename...and I thought the keyboard
quit working because whatever i typed in ...was invisible....the cursor moves...but nothing shows!! geez.
anyway, look at the picture and you will see what I see. I am sure this is NOT by design.
do i need to uninstall Softmaker and reinstall it again?
thank you for your help, I do appreciate it, I am just a little frustrated, is all.
By the way, this is in Linuxmint 14 xfce 64bit version, if that helps.
Post by sven-l » Tue Feb 12, 2013 11:58 am
I now installed FreeOffice in Debian 6.0.5 (Gnome) and Fedora 18 32bit with xfce. I could not reproduce that problem and all folder names are visible in the File=>Open dialog. I installed the .rpm archive via the shell with root permissions (-su) and rpm -ivh. Could you please check if that works better for you?
Return to “SoftMaker FreeOffice 2012 for Linux (General)”
