Laptop freezes on saving
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2012 for Windows
luc7v
Post by luc7v » Mon Jun 29, 2015 8:06 am
Hi,
I'm trying FreeOffice and it seems pretty cool. But I have a big problem.
I open a .doc and everything seems fast and nice. If I save the file on HDD, it seems to work. But if I save the file on a SD card, TextMaker freezes badly. Task Manager can't close it. Shutdown freezes too at some point. I must restart the computer and run check disk.
I tried with other SD cards, it's the same.
I can save on SD card from other programs.
I really need to save .doc on SD card. Any ideas?
Thank you,
Lucian
Re: Laptop freezes on saving
Post by Jossi » Mon Jun 29, 2015 12:23 pm
Quick 'n dirty workaround: Save to HDD, then copy to SD in Explorer.
But of course SoftMaker should inquire into this issue.
Post by sven-l » Wed Jul 01, 2015 10:14 am
luc7v wrote:Hi,
Thank you,
Lucian
I will refer that issue to our developers. Pleae try again with the next revision of FreeOffice as soon as it is available.
Return to “FreeOffice TextMaker 2012 for Windows”
