Highlight text function.
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2012 for Windows
Neutrino
Post by Neutrino » Thu Aug 22, 2013 4:49 pm
There doesn't seem to be a highlight text function anywhere. In other word processors this applies a configurable background colour (which is usually defaults to yellow) to a text selection to give the appearance of it having been highlighted with a marker pen.
Re: Highlight text function.
Post by martin-k » Thu Aug 22, 2013 8:50 pm
Format/Character/Background color. You can also place this on the toolbar.
Neutrino
Post by Neutrino » Thu Aug 22, 2013 9:20 pm
Yes obviously I do know that's possible, but I don't think that's really the same thing at all.
Selecting character formatting opens the full blown character formatting dialog, in which you then have to select the color you want. 4 separate mouse clicks are required to accomplish the task.
Highlight text button reduces this to 1 mouse click, or even better a configured hotkey.
Don't you think that would be a good idea?
Post by martin-k » Thu Aug 22, 2013 9:24 pm
You can have a background color dropdown on the toolbar. You just need to place it there.
Neutrino
Post by Neutrino » Fri Aug 23, 2013 10:43 am
Oh I see what you mean. Yes that's alright then, thanks.
ejspc1@gmail.com
Post by ejspc1@gmail.com » Sun May 08, 2016 3:27 am
I can find no answer regarding the highlight text function . As mentioned , there is no separate function to highlight text separate and distinct from A highlight comment . Reviewing your Program, textmaker 2012 , I was very impressed . However, highlighting Selected text is crucial to the way that I use a word processing program . Can you please add that! Thank you, EJS
Post by martin-k » Sun May 08, 2016 8:52 am
Install FreeOffice 2016 from http://www.freeoffice.com which comes with a Word-compatible text highlighter.
ejspc1@gmail.com
Post by ejspc1@gmail.com » Sun May 08, 2016 9:52 am
martin-k wrote:Install FreeOffice 2016 from http://www.freeoffice.com which comes with a Word-compatible text highlighter.
Thanks Martin! EJS :D
andres99
Post by andres99 » Sat Dec 10, 2016 9:48 pm
It is good to know that FreeOffice has Word-compatible highlighter but apparently FreeOffice does not save docx.
Our company has bought a number of commercial licences for Softmaker Office 2016 and we need to save docx too. Therefore it is not useful for us to replace the purchased version with the free version. It is also not convenient to install both and use FreeOffice when highlighting is needed.
Is there any way that we can get a Word-compatible highlighter (which you seem to offer free for other users) in the paid version?
Post by sven-l » Tue Dec 13, 2016 11:31 am
SoftMaker Office 2016 has all functions (and a lot more) of FreeOffice and it comes with a Word-compatible text highlighter.
Return to “FreeOffice TextMaker 2012 for Windows”
