incompatibility with DOC and ODT formats?
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2012 for Windows
ald
Post by ald » Tue Jan 15, 2013 12:44 pm
insert page break
insert table
save as ODT file
open it
(page break missing)
set paragraph-spacing before 20pt
insert table
save as ODT or DOC file
open it
(paragraph-spacing before missing)
(in TMD is everything ok)
I need: freeoffice - textmaker and planmaker, 50MB installation and 1sec of run-delay is maximum, less is more - less command-search, more time
Re: incompatibility with DOC and ODT formats?
Post by sven-l » Wed Jan 16, 2013 9:53 am
ald wrote:insert page break
insert table
save as ODT file
open it
This is reproducible for me. I informed the developers. Thank you!
Post by sven-l » Wed Jan 16, 2013 10:01 am
ald wrote: set paragraph-spacing before 20pt
insert table
open it
Could you please send a sample file for forum(at)softmaker.de? Thank you!
ald
Post by ald » Thu Jan 17, 2013 11:01 am
ok, I send it.
and there are some next bug:
run TextMaker with empty document
hit <Ctrl + F> Find
set Enlarge>Format>Character>Color - red (or Background) ... hit OK
use <Alt+Tab> to show another application in full screen (for example Adobe Reader)
use <Alt+Tab> to go back to TextMaker
(you will see only "Search Dialog" not full application)
(in Replace dialog is same problem)
Systray - Preferences
Einstellungen - title dialog is not translated into english
Post by sven-l » Thu Jan 17, 2013 11:23 am
Ald,
Please open a new thread for every new bug you find. Thank you!
Post by sven-l » Thu Jan 17, 2013 11:27 am
ald wrote:ok, I send it.
hit <Ctrl + F> Find
One question: Are you working with FreeOffice for Windows or Linux? I tried it with the Windows version but was not able to reproduce the problem. If you use Linux, which distribution? Thank you!
ald
Post by ald » Thu Jan 17, 2013 11:30 am
sorry, ok.
I use Windows XP Prof SP3
I reproduce it again.
Post by sven-l » Fri Jan 18, 2013 9:21 am
Ok, thank you! Anyone else who can reproduce this?
Fiex
Post by Fiex » Fri Jan 18, 2013 3:14 pm
sven-l wrote:Ok, thank you! Anyone else who can reproduce this?
No
Eggs?
Continuous Double-Click the "Search" or "Replace" Tab (<Ctrl + F> Find Box)
Post by sven-l » Mon Jan 21, 2013 2:16 pm
Fiex wrote: Eggs?
I double clicked like crazy on these two tabs but nothing happened. What happened on your side?
Post by sven-l » Tue Jan 22, 2013 9:17 am
insert table
save as ODT file
open it
This problem has been solved and should no longer occur with the next service pack.
Fiex
Post by Fiex » Mon Jan 28, 2013 1:20 pm
Win8 Compatibility?
Sometime TextMaker "Not Responding" on first startup
PS:I see the "Not Responding" in the title bar has 2 times
sven-l wrote:
Fiex wrote: Eggs?
Picture attachment
Find Box Eggs
Post by sven-l » Tue Jan 29, 2013 8:50 am
Thank you! I informed the developers.
Post by sven-l » Fri Feb 01, 2013 1:40 pm
Fiex wrote: Eggs?
There was a bug in this search dialog. This bug has been solved now (bugfix included in the next service pack).
Return to “FreeOffice TextMaker 2012 for Windows”
