Word doc with Excel table
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2012 for Windows
Rajah
Post by Rajah » Tue Jan 08, 2013 2:43 pm
Hi! I wish to edit table in Word document. I double click it and I see message (I translated it) - Programm, what needs to activate this Microsoft Excel 97-Tabelle is'n reachble. It is possible to convert or activate as other type of objects with Convert...
When I click button Convert, next window shows posibility to convert as Microsoft Excel 97-Tabelle only. After I press OK, nothing changes. It is not possible to activate.
Is there any solution to edit table without Excel?
Addition - I have no Excel in this computer.
Step by step, day by day...
Re: Word doc with Excel table
Post by sven-l » Wed Jan 09, 2013 9:43 am
So there is an Excel table embedded as OLE object inside the Word file? It should be possible to open it with PlanMaker (also part of FreeOffice). Have you associated all your Excel files types (.xls) with PlanMaker when you installed FreeOffice?
Rajah
Post by Rajah » Wed Jan 09, 2013 9:47 am
sven-l wrote:So there is an Excel table embedded as OLE object inside the Word file?
Yes
sven-l wrote: It should be possible to open it with PlanMaker (also part of FreeOffice).
I hoped so, it should be.
sven-l wrote:Have you associated all your Excel files types (.xls) with PlanMaker when you installed FreeOffice?
Yes, of course. It is same on another computer with FreeOffice.
I can add this file, if You need.
And another one - my native language is Latvian, we have diacritic signs - like umlauts. Ā, Ē, Č, Ķ. I do not see theese signs,
must be "Atrašanās vieta", but I have "Atrasanas vieta"
Addition. In next versions, please add this - after document saving let save button be grey, after correction in document, let this button colored. I hope You understand me.
Auto1.doc
(108.5 KiB) Downloaded 777 times
Post by sven-l » Tue Jan 15, 2013 10:48 am
Rajah wrote: Addition. In next versions, please add this - after document saving let save button be grey, after correction in document, let this button colored. I hope You understand me.
I will refer this to the developers.
Post by sven-l » Tue Jan 15, 2013 10:50 am
Rajah wrote:Hi! I wish to edit table in Word document. I double click it and I see message (I translated it) - Programm, what needs to activate this Microsoft Excel 97-Tabelle is'n reachble. It is possible to convert or activate as other type of objects with Convert...
This has been referred to the developers for further investigations.
Post by sven-l » Tue Jan 15, 2013 10:51 am
Rajah wrote: And another one - my native language is Latvian, we have diacritic signs - like umlauts. Ā, Ē, Č, Ķ. I do not see theese signs,
Please use another font that comes with the Latvian characters. Not every font contains these letters.
Rajah
Post by Rajah » Tue Jan 15, 2013 11:07 am
I'd love to, if You will tell me how to edit this table in document :lol:, by the way, this is default Windows Arial font, with all diacritic signs and normal Latvian letters and in other text documents it seems correct. [-X
Post by sven-l » Wed Jan 16, 2013 8:48 am
Changing font: Select the text (CTRL+A or select with mouse) and select another from the font selection in the toolbar.
Could you please send us a sample file to forum(at)softmaker.de to see the problem here?
Thank you!
Rajah
Post by Rajah » Wed Jan 16, 2013 3:44 pm
sven-l wrote:Changing font: Select the text (CTRL+A or select with mouse) and select another from the font selection in the toolbar.
Thank you!
Look above atachment - Auto1.doc
Post by sven-l » Thu Jan 17, 2013 10:35 am
Thank you. I will inform the developers.
Rajah
Post by Rajah » Tue Mar 19, 2013 3:37 pm
Hey, any news about my file?
Post by sven-l » Thu Mar 21, 2013 10:40 am
It works for me with the current version of SoftMaker Office. Please try again with the next update for FreeOffice as soon as it is available.
Rajah
Post by Rajah » Tue May 14, 2013 3:36 pm
sven-l wrote:Please try again with the next update for FreeOffice as soon as it is available.
Help - Check for updates and it says
Code: Select all
No updates have been found for your SoftMaker application
My version is SoftMaker FreeOffice TextMaker (rev 668) and my file DO NOT WORK. Have You a different version?
Post by sven-l » Wed May 15, 2013 9:32 am
There is no new version of FreeOffice available yet. Rev. 668 is still the older version. Please try again from time to time to see if the new version has been released.
Return to “FreeOffice TextMaker 2012 for Windows”
