SpellChecking problem
Post your questions, bug reports and suggestions here for FreeOffice TextMaker 2012 for Windows
simwin
Post by simwin » Wed Dec 12, 2012 12:05 pm
Hello! Thank you for the Freeoffice 8) But there are some problems with spellcheck in it.
I've installed russian and ukraine dictionaries. When I check the word - it is always with red underline and no suggestion for right variant.
How can I fix it?
Re: SpellChecking problem
Post by sven-l » Wed Dec 12, 2012 12:36 pm
Please make sure that you use the correct dictionary (Tools=>Options=>Language). Also, please select your text and check in Format=>Characters that the text is formatted in the correct language.
edit: I've moved your post into the TextMaker forum.
simwin
Post by simwin » Wed Dec 12, 2012 1:39 pm
sven-l wrote:Please make sure that you use the correct dictionary (Tools=>Options=>Language).
I've checked it. It's OK.
sven-l wrote:Also, please select your text and check in Format=>Characters that the text is formatted in the correct language.
Default language was there. I've selected - Russian. But problem not solved. Please report this bug to your developers.
Post by martin-k » Wed Dec 12, 2012 1:40 pm
I am not aware of such a problem. Could you send a sample document to forum (at) softmaker.de for further inspection?
simwin
Post by simwin » Wed Dec 12, 2012 5:40 pm
martin-k wrote:I am not aware of such a problem. Could you send a sample document to forum (at) softmaker.de for further inspection?
Send it with topic "Russian SpellChecking problem in FreeOffice"
Return to “FreeOffice TextMaker 2012 for Windows”
