How to move the Softmaker file.
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2012 for Windows that do not fit in any of the application-specific subforums.
Kilgetty
Post by Kilgetty » Tue Jul 14, 2015 2:21 pm
Hi, I have just installed Freeoffice and it makes a file in my "Documents" folder, I would prefer it to be in my "User" folder. There is provision in Tools/File to set the location of preference but unfortunately Freeoffice keeps changing it back to the "Document" folder. Is there any way I can make my change stick?
Re: How to move the Softmaker file.
Post by sven-l » Thu Jul 16, 2015 10:14 am
You can change the template folder in Tools=>Options=>Files but you cannot change the folder for the settings. They will always be stored in the documetns folder of your Windows. If you don't want that, you can create a mobile version (USB version) and use it instead. The USB version stores the templates and settings directly into the program folder:
http://www.softmaker.com/english/tipsof_en.htm
Return to “SoftMaker FreeOffice 2012 for Windows (General)”
