Problem installing FreeOffice revision 698
Post here those questions, bug reports and suggestions for SoftMaker FreeOffice 2012 for Windows that do not fit in any of the application-specific subforums.
Ambaquista
Post by Ambaquista » Thu Jan 29, 2015 12:36 pm
I download and install/update SoftMaker FreeOffice for Windows revision 698 and when I try to launch TextMaker, I get this message:
TextMaker
Unable to find a valid UI language file.
Please reinstall this application.
and exit!
I make a Repair instalation... samething
I make a Change instalation... samething!
The only diferrence in my instaling is changing the install folder:
c:\Utilities\SoftMaker FreeOffice\
in place of the common
c:\Program Files (x86)\SoftMaker FreeOffice\
Any idea?
BRgds
Ambaquista
Re: Problem installing FreeOffice revision 698
Post by sven-l » Thu Jan 29, 2015 12:54 pm
Please delete the following folders and try again:
- C:\Users\USERNAME\Documents\SoftMaker
- C:\Users\USERNAME\AppData\Roaming\SoftMaker
- C:\Users\USERNAME\AppData\Local\VirtualStore\Program Files (x86)\SoftMaker FreeOffice
Ambaquista
Post by Ambaquista » Thu Jan 29, 2015 1:46 pm
No. Same result!
I delete the 3 folders, restart the computer and... same message!
So I decide to uninstall the program and do another install
And it works! But... with the program in the folder
and docs in the folder
e:\Documents\SoftMaker\
So I need to make a portable instalation, uninstall the actual program, and copy the portable instalation to the folder
Thank you for your support
BRgds
Ambaquista
Post by sven-l » Fri Jan 30, 2015 3:24 pm
You can use the USB-setup to install it on a USB stick:
http://www.freeoffice.com/en/tips-and-t ... le-install
Return to “SoftMaker FreeOffice 2012 for Windows (General)”
