File open dialog cannot see windows server
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Linux that do not fit in any of the application-specific subforums.
EricC
Post by EricC » Fri Dec 14, 2012 1:19 am
Hi SMO Team,
The issue first reported in the SMO 2010 for Linux forums (link below) is still present with SMO2012 Rev674. As mentioned in that thread, other applications can see the files on the cifs mount just fine. It would be nice to have this issue fixed as manually copying files back and forth from the share to my machine to work on is not convenient.
Thanks,
-Eric
http://www.softmaker.com/forum/viewtopi ... unt#p31658
Re: File open dialog cannot see windows server
Post by sven-l » Fri Dec 14, 2012 10:08 am
This bug has not been solved yet. I will report here as soon as we have a solution.
EricC
Post by EricC » Fri Dec 14, 2012 4:40 pm
sven-l wrote:This bug has not been solved yet. I will report here as soon as we have a solution.
Thanks Sven. Hopefully this bug can be raised on the priority list.
-Eric
juliavasa5
Post by juliavasa5 » Sat Nov 22, 2014 6:20 pm
I have completely uninstalled and reinstalled SMO 674. Help/about says it is version 674.
I tried textmaker12 -debug , and here is the output.
[ 0s]: Date 26.11.2012, 14:18
[ 0s]: TextMaker 2012, Revision 674 (Linux)
[ 0s]: Main XWin handle: 33554433 [2000001]
[ 0s]: S64 - 64 bit os not detected.
[ 0s]: LibraryHandleCups: 148371840
[ 0s]: LibraryHandleCups - Full success!
[ 0s]: Gnome detected.
[ 0s]: LibraryHandleGnome: 0
[ 0s]: Tempfiles: /tmp/OUTXXXXXX
[ 0s]: gv installed
[ 0s]: ggv installed
[ 0s]: ghostview installed
[ 0s]: kghostview not installed
[ 0s]: XRender extension added successfuly.
[ 0s]: Optimizations: [Shared: 0]
[ 0s]: FontPathes: </home/barry/office2012/fonts:/usr/X11R6/lib/X11/fonts/Type1::/usr/local/lib/X11/fonts/misc/:/usr/local/lib/X11/fonts/TTF/:/usr/local/lib/X11/fonts/OTF:/usr/local/lib/X11/fonts/Type1/:/usr/local/lib/X11/fonts/100dpi/:/usr/local/lib/X11/fonts/75dpi/:/usr/local/lib/X11/fonts/dejavu/:/usr/local/lib/X11/fonts/bitstream-vera/:/usr/local/share/fonts:/usr/local/lib/X11/fonts:/home/barry/.fonts>
[ 0s]: Init Fontcache (341)
[ 1s]: comInit: CmdLine
[ 1s]: CmdLine <>
[ 1s]: comInit: Address
[ 1s]: comInit: InitCountry
[ 1s]: Countrycode set to <en_US.UTF-8>
[ 1s]: Country Settings1: ID:1 CP:0 Curr:$ CF:0 NF:12 TS:, DS:.
[ 1s]: Country Settings2: MS:2 LS:, Lng:enu
[ 1s]: Country Settings Date: DF:3f41 DS:/ DW:, D1S: D2S:,
[ 1s]: Country Settings Time: TF:0 TS:: TA:AM TP:PM
[ 1s]: comInit: Controls
[ 1s]: comInit: Res
[ 1s]: comInit: Install
[ 1s]: comInit: InitPrefs
[ 1s]: comInit: InitMenu
[ 1s]: comInit: CreateMain
[ 1s]: comInit: Menuhelp
[ 1s]: comInit: CtlStrips
[ 1s]: comInit: Colors
[ 1s]: comInit: WindowSize
[ 1s]: comInit: Treeview
[ 1s]: comInit: appData
[ 1s]: wpInit: Brushes
[ 1s]: wpInit: Format
[ 1s]: wpInit: Cursors
[ 1s]: wpInit: Icons
[ 1s]: wpInit: Register
[ 1s]: wpInit: RegisterClass
[ 1s]: wpInit: Menus
[ 1s]: wpInit: Buffer
[ 1s]: wpInit: Fonts
[ 1s]: wpInit: Accelerators
[ 1s]: wpInit: Fax
[ 1s]: wpInit: Printer
[ 1s]: wpInit: SetPrinter
[ 1s]: wpInit: Quickpath
[ 1s]: wpInit: History
[ 1s]: wpInit: Bullets
[ 1s]: comInit: configFile
[ 1s]: Cached ini files after startup:
[ 1s]: /home/barry/.softmaker/fontfilter.ini
[RestrictedFonts]
ResFontsNumber=0
[ 1s]: /home/barry/.softmaker/tm12config.ini
[PrinterList]
GhostView [System]=2
lp [CUPS] #2=1
[SM Printer - GhostView [System]]
PrinterCmd=gv % ; rm %
PrinterOutput=1
Resolution=300
RotLandscape=1
[DefaultPrinter]
DefaultPrinter=lp [CUPS] #2
[tm]
LinuxInfo=2012.LX.674.1
BetaMsgShown=1
TipOfDayShow=0
TipOfDayEasy=1
DlgLID=1033
TemplatePath=/home/barry/SoftMaker/Templates 2012/
Documents=/home/barry/Documents/
Databases=/home/barry/SoftMaker/
Pictures=/home/barry/SoftMaker/
Macros=/home/barry/SoftMaker/
WinSize=329,166,1673,1006
TimeFormat=
DateFormat=
TimeFlags=0
DateFlags=0
SidebarDocking=3
SidebarRatio1=-1
SidebarRatio2=0
HideSBFullScreen=0
SidebarPage=3370
SidebarDocumentMap=1
SidebarHeadingLevel=9
SidebarCharstyleShow=0
SidebarPgfstyleShow=0
SidebarFlags=1023
WSColorEnabled=0
WSColorRGBValue=8421504
LanguageID=1033
SpellRule=1
InfoDropdown=1
HorizontalPages=32
NewFilePreviewDlgZoomWinext=0
FileDlgSize=477,346
FileDlgColumns=150; 90; 129
PrintPreviewMode=0; 1440
PdfOptAfQuality=2
WinMax=0
[UserHome]
Name=
[SM Printer - lp [CUPS] #2]
PrinterCmd=[cupscmd] lp
PrinterOutput=1
Resolution=300
RotLandscape=1
[tm History]
HistoryFile0=-1,0,/home/barry/Documents/SelfReview.tmd
HistoryFile1=-1,0,/home/barry/Documents/FAQ.tmd
HistoryFile2=0,0,/home/barry/Documents/SelfReview.bak
HistoryFile3=-1,0,/home/barry/Documents/ooo.tmd
HistoryFile4=0,0,/home/barry/.opera/temporary_downloads/TCI-TN40G-DSMPLL-partial.rtf
HistoryFile5=0,0,/home/barry/.cache/evolution/tmp/evolution-barry-j5Ybn8/Message.rtf
HistoryFile6=
HistoryFile7=
HistoryFile8=
HistoryFile9=
[ 1s]: /home/barry/.softmaker/install.ini
[Install2012]
DefaultDocumentPath=/home/barry/SoftMaker/
en=Installed
[ 1s]: comInit: Speller
[ 1s]: comInit: appCmdList Start
[ 1s]: LoadDocument </home/barry/SoftMaker/Templates 2012/English/Normal.tmv>
[ 1s]: comInit: appCmdList End
[ 1s]: comInit: ShowWindow
[ 1s]: comInit: TipOfDay
[ 1s]: comInit: Timer
[ 1s]: comInit: AutoLoad
[ 1s]: comInit: Dispatch
[ 15s]: LoadDocument </home/barry/Documents/SelfReview.tmd>
[ 23s]: PrintDocument </home/barry/Documents/SelfReview.tmd> on <lp [CUPS] #2>
[ 35s]: CloseApp
[ 35s]: Shutdown: Memory
[ 35s]: Shutdown: AppCleanup
[ 35s]: Shutdown: ClearString
[ 35s]: Shutdown: CleanupDialog
[ 35s]: Shutdown: Complete
Thank you......!!!
**SignaturE**
Post by sven-l » Mon Nov 24, 2014 8:18 am
Revision 674 is outdated. Please try again with rev.695 (you have to download the installation file again from the e-mail with the serial key in it):
http://www.softmaker.com/english/servofl12_en.htm
Return to “SoftMaker Office 2012 for Linux (General)”
