data export from Planmaker to Textmaker
Post your questions, bug reports and suggestions here for PlanMaker 2012 for Linux.
Cikorium
Post by Cikorium » Thu Mar 26, 2015 8:01 am
Hi! How to export data from Planmaker table cells to Textmaker table cells. Copy/Paste dont work correctly! In MS Office I use copy/paste without any problem. Help me!!!
Re: data export from Planmaker to Textmaker
Post by Jossi » Thu Mar 26, 2015 8:29 pm
Probably you selected the cells of the TextMaker table before inserting. This doesn't work. Just set the cursor into the first cell of the insertion range, then Ctrl+V will insert the content correctly. It is also possible to set the cursor somewhere into the text, then Ctrl+V will automatically create a new table with the copied content at the position of the cursor.
As TextMaker is not a spreadsheet program, PlanMaker formulas are of course not copied but replaced with the result.
Return to “PlanMaker 2012 for Linux”
