Display error
Post your questions, bug reports and suggestions here for PlanMaker 2012 for Linux.
Mark Davies
Display error
Post by Mark Davies » Sat Apr 20, 2013 1:32 pm
I'm trying out SM for Linux on Mint 14. TM and Presentations seem to work OK, but PM is displaying in a miniaturized form in the top left fo the screen! Its menus seem unresponsive to mouse clicks. I'm new to Linux and don't know what to make of this.
Mark Davies
Mark Davies
Re: Display error
Post by Mark Davies » Sun Apr 21, 2013 10:41 am
After a reboot, it's not so bad. The window still won't move from the top left corner, but it's bigger and can be viewed at a bigger size, However, the mouse pointer is not accurate; it clicks on things about half a centimetre above and to the left of its tip.
Mark Davies
Re: Display error
Post by sven-l » Tue Apr 23, 2013 1:02 pm
Sounds strange. Can you invoke the menus? If yes, you can try to change the dialog style in Tools=>Options=>Appearance. Maybe it makes a difference.
Mark Davies
Re: Display error
Post by Mark Davies » Wed May 01, 2013 6:46 am
Sorry not to reply, but I've now deleted the dual-boot installation of Linux and I'm using it in Virtual Box. When I get around to re-installing SM, I'll let you know if I get the problem again.
Mark Davies
Return to “PlanMaker 2012 for Linux”
