negative values in red
Post your questions, bug reports and suggestions here for PlanMaker 2012 for Linux.
brampie66
Post by brampie66 » Wed Dec 12, 2012 4:42 pm
when you tick "negative values in red" the negative values appear in white (not visible) in planmaker12 for linux
when you use "aangepast" and type "# ##0,00\ "€";[Rood]\-# ##0,00\ "€"" this does work
Re: negative values in red
Post by sven-l » Thu Dec 13, 2012 9:00 am
I cannot reproduce this problem in Debian Linux 6.0.5 32 bit with PlanMaker rev.674, so I need a bit more information:
1. Which Linux do you use?
2. Is rev.674 or an older revision of PlanMaker installed (Menu=>Help=>About)?
3. Does the problem occur with every (even new created) files?
4. Which graphic card and driver are you using?
Return to “PlanMaker 2012 for Linux”
