Insert footnote problems
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
Kazza1
Post by Kazza1 » Sun Mar 19, 2017 8:47 am
Have tried inserting a paragraph into a footnote on a document and App crashes every time.
Can insert a short footnote, but I've tried to add to the footnote and will only let me type over the footnote, but not add to it. Oddly, Footnote also appears in body of document, where the text appears in the same formatting as in the body of the document, but the footnote does not show the new text.
Re: Insert footnote problems
Post by sven-l » Tue Mar 21, 2017 10:54 am
Does that also happen with TextMaker HD for Android (you can find a free Basic version in the Playstore)?
Kazza1
Post by Kazza1 » Thu Mar 23, 2017 6:39 pm
Thank you for bringing Textmaker hd to my atttention. I was quite excited to see a program that is much more familiar to me and has so much more to offer.
Could not get the footnote to work, as it seems to be only available in the paid version. However the footer is in the HD version and works well.
Cheers
Post by sven-l » Fri Mar 24, 2017 10:57 am
Yes, it's a feature of the paid version.
Return to “TextMaker Mobile for Android”
