Disappearing Action Bar Menu
Post your questions, bug reports and suggestions here for TextMaker Mobile for Android.
Akjohnston
Post by Akjohnston » Fri Mar 28, 2014 11:01 am
Hi,
I'm having an Intermittent problem with the latest version of TextMaker on my Galaxy Note 10.1 tablet. About one time in 2-3 after the document loads the menu disappears and I have to exit out with the back button and start again. This has now happened several times.
Andrew
Re: Disappearing Action Bar Menu
Post by sven-l » Mon Mar 31, 2014 10:40 am
I have not heard of other customers reporting such a problem. Does it help to uninstall and re-install TextMaker?
Akjohnston
Post by Akjohnston » Mon Mar 31, 2014 11:09 am
Hi,
No, I've just tried doing this and the third time I started TextMaker the menu disappeared!
Andrew
Post by sven-l » Tue Apr 01, 2014 11:10 am
Thank you for the info! Which Android version is installed on your Galaxy Note 10.1 tablet?
Akjohnston
Post by Akjohnston » Tue Apr 01, 2014 12:13 pm
It's 4.1.2
Andrew
Post by sven-l » Wed Apr 02, 2014 11:26 am
Ok, thank you! I referred that problem to our developers. Please check that you work with the new revision 689 of Office for Android.
Akjohnston
Post by Akjohnston » Wed Apr 02, 2014 12:01 pm
Hi,
I have just seen the new versions. I will install those and let you know if the problem is solved.
Andrew
Akjohnston
Post by Akjohnston » Wed Apr 02, 2014 12:19 pm
Hi,
On a quick check the problem may be solved with the new version. I'll let you know if not...
Andrew
Akjohnston
Post by Akjohnston » Fri Apr 11, 2014 10:51 am
Hi,
The problem is still occurring with the latest version - I have just had it twice out of three times attempting to open a document. I'm using V 689.0328.ac
Andrew
Post by sven-l » Mon Apr 14, 2014 9:05 am
Ok, thank you for the reply! I referred that problem again to the developers for some investigations and will inform you as soon as there are any news.
Post by sven-l » Tue Apr 22, 2014 4:24 pm
Our developers need some information in that case. There shouldn't be a menu because the device has a hardware menu button (at the bottom). If you don't mean the menu button, please tell us what exactly is missing (maybe a screenshot/photo could help). Thank you!
Akjohnston
Post by Akjohnston » Wed Apr 23, 2014 12:15 am
There should be a menu indicated by three dots at the top right on a larger tablet. On a smaller device or one with a hardware menu button, this appears at the bottom left but it's the same menu. This is there exactly where it should be about half the time. About half the time the three dots at the top of the screen are not visible. That's the problem.
Andrew
mwise69
Post by mwise69 » Fri May 02, 2014 3:36 pm
Hi. I have the same disappearing menu button problem on my Nexus 5 running Android 4.4.2 and latest Textmaker from Play Store.
Return to “TextMaker Mobile for Android”
