Greek Fonts not supported
haga
Post by haga » Sat Jun 14, 2014 6:05 pm
I noticed that the following Greek phonemes + final 's' are not correctly displayed:
ά, έ, ί, ό, ύ, ή, ς
Re: Greek Fonts not supported
Post by sven-l » Mon Jun 16, 2014 2:45 pm
Please make sure that the font used in the document is properly installed on your device. If not, TextMaker uses some replacement fonts and that can be the reason for the problem you describe.
More infos for font installing in Android:
http://www.softmaker.com/english/tipsandroid_en.htm
haga
Post by haga » Tue Sep 30, 2014 10:17 pm
The suggested solution works only for the opened documents - not the GUI.
Thankfully this issue is fixed in new 'HD' (beta) version.
