Hi everyone!
I'm a relative new user to the program and really love it! My only issue is that I am working on a galaxy note 10.1 and I like to cut(copy) and paste from other documents into my open textmaker file. It will do this as long as I only choose text that doesn't have any more than one paragraph of text....In other words if I go to copy two paragraphs of text from another program or doc, it will not recognize it in my textmaker file, it just copies a blank space....This happens also if it is one line of text on top of each other ie..
the dog barks
I don't like it when the dog barks
If I go to copy this type of format from another doc into my textmaker file it will not except it...
Is there a workaround for this?? It really limits me on productivity...Cheers, jeff
Copy and paste INTO textmaker mobile
Re: Copy and paste INTO textmaker mobile
Jeff,
From which external app do you try to copy&paste into TextMaker? Does Menu=>Edit=>"External Paste" do the job? Which device, Android version and TextMaker revision (Help=>About) are you using?
WOW! Where has that been! lolsven-l wrote:Jeff,
Cheers that worked GREAT!
