Problems recognizing Google Docs format (Revisited?)
hogueax
Post by hogueax » Tue Jul 16, 2013 1:34 am
Hi, I'm currently on the trial version of Textmaker for Android and am having trouble getting it to recognize and access files from my Google Drive. I found this thread from 2008 outlining most of the problems I'm experiencing, but was no help in solving the problem: http://www.softmaker.com/forum/viewtopi ... mat#p44229
While Textmaker will show that there are files in my Drive if I select "All Files," I am unable to access them just like the user in the linked thread. It gives me an error message saying: "An error occurred! The Google Docs file format is not supported" However, if I go into Drive and re-save the files as .docx, then they are immediately available for editing in Textmaker. I have quite a substantial amount of documents in my Drive, and hope there is a better option than going back through each and every file and manually re-saving it.
Danke im Voraus für die Hilfe und schöne Grüße aus den USA!
Alex
Re: Problems recognizing Google Docs format (Revisited?)
Post by sven-l » Tue Jul 16, 2013 8:50 am
Alex,
Are you using Google Docs Cloud Sync or do you access Google Drive directly via TextMaker's File=>Open menu?
hogueax
Post by hogueax » Tue Jul 16, 2013 1:06 pm
Hi Sven,
I'm accessing Drive directly from Textmaker's menu. It may also be useful to include that I'm using an Asus Transformer Infinity (TF700T) that is running Android 4.2.1.
Alex
Post by sven-l » Wed Jul 17, 2013 9:25 am
I tested it with TextMaker Mobile rev.678.325 (full version) on a Vestel tablet and have no problems accessing my .docx and .tmd files in Google Drive with "All documents". You wrote that you have to re-save the files in .docx file format. What file format are the files before (when you receive the error messaage)? Was the files created in TextMaker or in another program?
