Outline view
Post bug reports and suggestions for TextMaker 2012 for Linux.
gminnerup
Outline view
Post by gminnerup » Wed Aug 22, 2012 12:23 pm
Outline view is often used to plan a piece of writing but unlike Word, for example, the current behaviour does not make that easy: Enter a first heading and RETURN, and the next line is plain body text which then has to be manually "promoted". It would be better to have the next line at the same outline level/heading style than the previous which is what people would mostly want.
Re: Outline view
Post by sven-l » Thu Aug 23, 2012 11:14 am
I will refer that as a suggestion to our developers.
Return to “Public beta: TextMaker 2012 for Linux”
