Typing lag
Post bug reports and suggestions for TextMaker 2012 for Linux.
toomanymatts
Typing lag
Post by toomanymatts » Thu Aug 16, 2012 9:10 am
Tried it for the first time on a document last night, pasted in some comments from an email and tried to type in line...big time issues with typing lag. I would type - say - 'the cat sat on the mat'...look up at a blank screen and watch as a few seconds later 't.....h.....e...........c....a....t' appeared on the screen.
Presently using LibreOffice and had never had an issue like that before, so can rule out it being an issue of hardware/processing power.
Re: Typing lag
Post by sven-l » Thu Aug 16, 2012 10:43 am
Which Linux version are you using? Does it help if you switch off SHM or XIM in Tools=>Options=>System?
toomanymatts
Re: Typing lag
Post by toomanymatts » Thu Aug 16, 2012 1:01 pm
Ubuntu 12.04 - will play with that tomorrow when I am back at the office and let you know.
toomanymatts
Re: Typing lag
Post by toomanymatts » Fri Aug 17, 2012 10:57 am
turned both off, no different. Similar issues selecting text...really sloooooow. Unusably slow for me in this beta (sorry!)
Also I noticed that there is no launcher icon coming up for Textmaker in Ubuntu when its open, just an empty space there (which when clicked on, does open the window)
Re: Typing lag
Post by sven-l » Fri Aug 17, 2012 11:04 am
Thank you! I informed the developers.
Re: Typing lag
Post by sven-l » Tue Aug 21, 2012 2:44 pm
We need a bit more information:
- Which system is used (CPU, Graphics card, Notebook, Netbook, etc.)?
- Does the lag happen in new empty documents, small documents, big documents?
Thank you!
DavidAJA
Re: Typing lag
Post by DavidAJA » Fri Sep 21, 2012 2:26 am
I post under previus discussion
Two glitches in second beta
http://www.softmaker.com/forum/viewtopi ... 00&t=11493
Perhaps could be Automatic separation of syllables. Someone can try disablig it? It work to me. But it is a necessary tool.
David Atonaltzin
Re: Typing lag
Post by martin-k » Fri Sep 21, 2012 2:26 pm
David, I cannot really believe that hyphenation is the culprit.
But yes, please all affected customers should try and report back if turning it off makes a change. It would also be interesting if turning off the sidebar changes the speed.
toomanymatts
Re: Typing lag
Post by toomanymatts » Mon Sep 24, 2012 5:57 am
sven-l wrote:We need a bit more information:
Thank you!
Sorry - hadn't looked in on this thread in a while (basically til I got notification of the new beta)
In the current (Beta 3) this lag persists, but is not as bad as it was in previous.
I'm using a Dell Vostro V13, Celeron 1.3 ghz, 2gb ram, i'm not sure what graphics card is in this, but I don't have issues with any other applications. Running ubuntu 12.04.
Re: Typing lag
Post by martin-k » Mon Sep 24, 2012 8:34 am
Thank you for the update. I will inform the developers.
Return to “Public beta: TextMaker 2012 for Linux”
