Textmaker Freezes if save as MS Word is used.
Help for TextMaker 2002 for Handheld PCs
montevale
Post by montevale » Mon Apr 25, 2005 6:00 am
I use MobilePro 780, textmaker rev.405
When I use save as: MS Word 97/2000/XP the programs hangs up.
I just downloaded the trial version, is that part of the limitation of the trial?
Tobias-L
Post by Tobias-L » Mon Apr 25, 2005 8:46 am
Well, some more details would be helpful:
Do you run TextMaker from a storage card or internal memory?
Did you save to storage card or internal memory?
Are you able to save to tmd, in both storage card and internal memory?
Tobias Leißner
montevale
Post by montevale » Tue Apr 26, 2005 4:25 am
I ran TextMaker from internal memory.
I tried saving .doc to internal memory and to a CF card.
tmd is save ok when I try saving .doc it hangs.( 97/2000/xp)
Tobias-L
Post by Tobias-L » Tue Apr 26, 2005 9:17 am
OK, when saving to tmd works then please send us this tmd file and we will try to save it in doc format. Send the file to support(at)softmaker.de
Tobias Leißner
marios
Easymate 770 Freeze with word
Post by marios » Mon Jun 13, 2005 4:48 pm
I too have a problem with the system freezing/crashing when word is selected for save, also when I try to access the preferences, all was ok in previous trial version, I have it saved on memeory card ( 1 Gig) and am saving to memory card, if I save in tmd all ok, I have been reading posts that you keep replying that this seems isolated, but it is not, my processor is mips 4000
Tobias-L
Post by Tobias-L » Tue Jun 14, 2005 8:22 am
Well, let's talk about it in the other thread you started:
http://www.softmaker.net/forum/viewtopic.php?p=5517
Tobias Leißner
Return to “TextMaker 2002 for Handheld PCs”
