Disappearing icons in the toolbar
Post bug reports and suggestions for SoftMaker Office2012 for Linux.
EricC
Post by EricC » Tue Sep 04, 2012 4:51 am
Hi Sven and Co.,
I am having an issue with the icons disappearing/reappearing in the toolbar if I hover over the icons with my mouse pointer. This issue happens on my T60 laptop with an ATI Radeon Mobility X1300 discrete graphics card. This issue started when I changed the Dialog Style to something other than Linux (Windows 7 Gray, etc.).
I have reproduced this issue on the same laptop with the following distributions (all 32bit):
Slackware 13.37
Slackware 14.0 RC4
CentOS 6.3
My initial thought is that the issue is with how SoftMaker Office is interacting with the ATI driver from Xorg. Since ATI no longer provides a proprietary driver that will work with the recent Xorg releases, I cannot compare the two to determine if the issue is with the Xorg driver.
None of the other applications I run on the laptop (Browsers, LibreOffice, etc.) have this issue.
I have attacted some screenshots to give you a better idea of what I am talking about. I am also attaching the Xorg logfile from Slackware 14.0 RC4 to see what all is transpiring when X is launching.
This issue is present with the first and second beta.
-Eric
EricC
Re: Disappearing icons in the toolbar
Post by EricC » Tue Sep 04, 2012 4:53 am
Here are the last two files.
Xorg.0.log
(42.41 KiB) Downloaded 153 times
Post by sven-l » Wed Sep 05, 2012 9:32 am
Thank you for the bug report! I informed the developers.
Post by sven-l » Wed Sep 05, 2012 2:02 pm
Does it help to disable SHM extensions in Tools=>Options=>System?
EricC
Post by EricC » Thu Sep 06, 2012 1:52 am
Hi Sven,
The checkbox for SHM extensions is greyed out. So I cannot deselect it.
Return to “Public beta: General”
