Menu & Dialog Fonts
Post bug reports and suggestions for SoftMaker Office2012 for Linux.
RRJ
Menu & Dialog Fonts
Post by RRJ » Wed Aug 15, 2012 10:33 pm
I just installed on 64 bit Fedora 14.
The menu and dialog fonts are so small as to be almost unreadable, is there any way of changing them?
RRJ
Re: Menu & Dialog Fonts
Post by RRJ » Wed Aug 15, 2012 10:43 pm
Ok, I changed the dialogue style from Linux to Wndows 7 and now they are about the same size as Linux menus and dialogs in other applications. Still it would be nice to have Linux style in a normal font size.
Post by sven-l » Thu Aug 16, 2012 8:04 am
I will refer this as a feature request to our developers.
Post by sven-l » Tue Aug 21, 2012 2:22 pm
Could you please send us a screenshot of the problem with the menu and dialog fonts (either attach it here or sent it to forum(at)softmaker.de referring to that thread)? Thank you!
RRJ
Post by RRJ » Wed Aug 22, 2012 11:26 am
See attached screen shots.
The LinuxDialogs is as it appeared on installation
The WindowsDialogs is after I selected Windows 7 dialog style and use large icons.
I am running it under Fedora 14 in a VirtualBox.
It occurred to me that the arbitrary screen resolution set by resizing the containing Window may be a factor.
It was running at 1748 x 936 so I tried resizing to 1024 x 768 but it made no difference.
Hope this helps,
Richard
Post by martin-k » Wed Aug 22, 2012 11:27 am
Can you go to Tools/Option and check ON the option "Window Manager dialogs"? Does this change anything?
RRJ
Post by RRJ » Wed Aug 22, 2012 11:32 am
I just tried that and it made no difference
Richard
Post by sven-l » Thu Aug 23, 2012 9:26 am
Thank you! I referred your screenshots to the developers.
Post by sven-l » Fri Aug 31, 2012 12:43 pm
The menus should look better in the next beta.
RRJ
Post by RRJ » Tue Sep 04, 2012 3:22 pm
I can confirm its OK in the latest Beta - thanks
Return to “Public beta: General”
