Support for Listary Pro
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Windows that do not fit in any of the application-specific subforums.
ckit
Postby ckit » Thu Dec 29, 2011 3:37 pm
Hi,
I have Listary Pro 3.23 (latest is 3.50 but I have a GiveawayOfTheDay free version license only for 3.23) installed, both SoftMaker Office 2010 and 2012 Std have trouble displaying Listary's add-on thing. SoftMaker Office uses non-standard open\save file dialog windows which is a disaster for other apps like Listary Pro!
Any plans to support Listary Pro - http://www.listary.com ?
Thank you,
ckit.
Re: Support for Listary Pro
Postby Jossi » Thu Dec 29, 2011 6:46 pm
In Tools > Options..., tab "Appearance", you can select "Use system file dialogs". Does that make it better?
ckit
Postby ckit » Fri Dec 30, 2011 2:38 am
Jossi wrote:In Tools > Options..., tab "Appearance", you can select "Use system file dialogs". Does that make it better?
"Use system file dialogs" was enabled already, disabling it, activates SoftMaker Office's own dialog which Listary doesn't recognize and won't appear.
For now, I'm disabling support for each SoftMaker Office app in Listary until I sent them an email about it and I'll probably purchase their latest version too.
Thank you,
Chris.
Return to “SoftMaker Office 2012 for Windows (General)”
Who is online
