I owe SMO 2010 but it's not installed now.Can I buy upgrade?
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Windows that do not fit in any of the application-specific subforums.
LieberDeutsch
Post by LieberDeutsch » Thu Dec 15, 2011 12:20 am
Dear people,
I'm thinking of buying SMO 2012, because I'm a die-hard MS-Office user and are very curious if SMO is compatible.
But... before I purchase anything, I want to be sure I'm ordering the right version.
Right now, I haven't installed SMO 2010. Does SMO 2010 have to be installed to be able to install the upgrade of 2012? Or is the upgrade version a full version too and can I install it whenever I feel like it, without having SMO 2010 running on my system?
Thanks in advance for your answer.
Kind regards,
LieberDeutsch
Re: I owe SMO 2010 but it's not installed now.Can I buy upgr
Post by martin-k » Thu Dec 15, 2011 9:18 am
You do not have to have the older version installed to install the upgrade.
I checked our customer database, and you own SoftMaker Office 2010. This entitles you to purchase at upgrade pricing.
LieberDeutsch
Post by LieberDeutsch » Thu Dec 15, 2011 10:18 am
Thank You for this fast and clear answer Martin! :thumbsup: Now I can purchase without worries. :)
Kind regards,
LieberDeutsch
Return to “SoftMaker Office 2012 for Windows (General)”
