I can't even install!
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Windows that do not fit in any of the application-specific subforums.
yowlingcat
Post by yowlingcat » Thu Dec 15, 2011 12:06 am
Running W7 64 bit.
I get to the panel where I choose English, I select English and then ... nothing. Nothing at all happens. Certainly, no software gets installed.
Very frustrating - I just bought this stuff!
I uninstalled the 2010 version and also the beta of 2012 before trying to install.
rjstep3
Re: I can't even install!
Post by sven-l » Thu Dec 15, 2011 10:01 am
Can you please attached the smo12msi.log and the smo12bs.log? You will find these logfiles in the temp folder (Start=>Run=>Enter '%temp%'). This would help us to find out what the problem is.
Thank you!
yowlingcat
Post by yowlingcat » Thu Dec 15, 2011 7:58 pm
smo12bs attached - there is no smo12msi in the temp folder.
regards
rjstep3
smo12bs.log
(187.79 KiB) Downloaded 181 times
Post by sven-l » Fri Dec 16, 2011 9:45 am
Thank you! I referred that problem to our developers and will inform you here as soon as we have a solution.
Post by sven-l » Fri Dec 16, 2011 12:48 pm
I wrote you an PM.
yowlingcat
Post by yowlingcat » Sun Dec 18, 2011 1:11 pm
thanks, that worked.
rjstep3
Return to “SoftMaker Office 2012 for Windows (General)”
