system tray
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Windows that do not fit in any of the application-specific subforums.
fpefpe
system tray
Post by fpefpe » Thu Dec 25, 2014 1:07 am
Hello -- how do you turn on the icons in the system tray?
Re: system tray
Post by Jossi » Thu Dec 25, 2014 3:17 pm
Did you install the SMASH application together with SoftMaker Office? This should do the trick.
fpefpe
Re: system tray
Post by fpefpe » Thu Dec 25, 2014 5:21 pm
Jossi wrote:Did you install the SMASH application together with SoftMaker Office? This should do the trick.
I just did the std install from the one exe file -- I see from the setting / options about smash -- thx for the reply --
Return to “SoftMaker Office 2012 for Windows (General)”
