Issue with installing and using Megafont XXL 2.0
Post here those questions, bug reports and suggestions for SoftMaker Office 2012 for Windows that do not fit in any of the application-specific subforums.
Nicsam
Postby Nicsam » Fri Feb 24, 2012 2:45 am
Hello,
I hope someone can help me. I just bought Megafont XXL 2.0 and when I try to install it I get this message:
Registry could not be opened for Software\Microsoft\windows NT\CurrentVersion\Type 1 Installer\Type 1 Fonts.
It then will open the font manager even though it is not installed. So if I try to install a font I get this message:
Write error. Disk full or insufficient rights to write in the destination folder.
I am running Windows 7 Pro version. I have tried to change the compatibilty settings for the program but that doesn't make any difference.
Any suggestions on what else I can do?
Thanks so much!
Re: Issue with installing and using Megafont XXL 2.0
Postby martin-k » Fri Feb 24, 2012 9:38 am
You need to run the font installer as administrator (right-click on the application icon and choose "Run as administrator").
The message at the beginning is harmless and can be ignored.
Nicsam
Postby Nicsam » Fri Feb 24, 2012 4:11 pm
Hi Martin,
I tried that and I still get the same message: Registry could not be opened for Software\Microsoft\windows NT\CurrentVersion\Type 1 Installer\Type 1 Fonts.
Any other thoughts?
Thanks so much.
Postby martin-k » Fri Feb 24, 2012 4:16 pm
As I said, the message at the beginning is harmless and can be ignored. When you click it away, the font manager will run.
Nicsam
Postby Nicsam » Fri Feb 24, 2012 4:27 pm
I don't get that message though. When I insert the CD it automatically starts installing. So I just opened the contents of the CD and right clicked on "run as administrator" and then I still get that same message.
Postby sven-l » Mon Feb 27, 2012 10:39 am
Nicsam wrote:...So I just opened the contents of the CD and right clicked on "run as administrator" and then I still get that same message.
And does it work if you click that message away, select a font in the font manager and click on "install"?
Nicsam
Postby Nicsam » Thu Mar 01, 2012 3:33 am
No, when I click that message it just knocks me out of the program.
Postby sven-l » Thu Mar 01, 2012 10:20 am
I don't know why this happens. I never heard of such a problem with the font manager. You can still install the fonts. Just copy the desired files from the CD to you HDD, unzip them and copy the font files to the font folder of your system (should be C:\WINDOWS\Fonts).
Return to “SoftMaker Office 2012 for Windows (General)”
Who is online
