eMClient- connects to various IP ads
Post bug reports and suggestions for SoftMaker eM Client Professional 4 for Windows.
Princy557
Post by Princy557 » Tue Dec 06, 2011 8:19 am
Hi,
I've not got it setup yet, but each time I have run eMClient it connects to a number of IP addrress's.
184.154.58.124
88.86.110.67
64.12.249.162
all port 80
Why?
What information is extracted by these IP address's?
Regards
Princy557
Re: eMClient- connects to various IP ads
Post by sven-l » Tue Dec 06, 2011 1:17 pm
The first two addresses are eM Client licensing server and the RSS news service which is set in eM Client as widget by default (it can be disabled in menu Tools->Settings->Widgets, it's eM Client RSS) so it is completely normal.
The third IP address is some AOL address so you must have set some account that connects to it.
Princy557
Post by Princy557 » Tue Dec 06, 2011 3:00 pm
Hi Sven,
Thanks for the checkup,
Part one, OK I will disable after this response....
Part two,
I have currently set NOTHING on eMClient. I'll have to do some tracing on that one then. If I find anything out I'll respond here....
Regards
Princy557
Princy557
Post by Princy557 » Tue Dec 06, 2011 3:15 pm
Further info
64.12.249.162 my Firewall tells me that also is eMClient. does not tell me what it is doing, but that's alos
with emClient...
Regards
Princy557
Post by martin-k » Tue Dec 06, 2011 3:21 pm
Maybe you are looking at an e-mail that references a picture there?
Princy557
Post by Princy557 » Tue Dec 06, 2011 3:25 pm
Ventured into the Widgets secction switched off the RSS
I now have NOne of the above IP's trying to connect etc....
So Job sorted...
Cheers
Regards
Princy557
Return to “SoftMaker eM Client Professional 4 for Windows”
