Progression to mail above following Deletion of mail
Post bug reports and suggestions for SoftMaker eM Client Professional 4 for Windows.
basils57
Post by basils57 » Sat Sep 15, 2012 2:27 pm
When I delete an email, is there a way to make the highlight move to the mail above the deleted one, rather than moving down to the one which followed it?
Re: Progression to mail above following Deletion of mail
Post by martin-k » Sat Sep 15, 2012 3:01 pm
No. The visual effect is that the highlight bar stays in its current position, with the next mail "sliding" underneath. It would look a bit weird if the highlight bar moved up.
But why don't you simply change the sort order of your e-mails? If you change them from ascending to descending (or vice-versa), you have the effect that you desire -- you delete in the opposite direction.
Return to “SoftMaker eM Client Professional 4 for Windows”
