eM Client Uses A Huge Amount of Memory
Post bug reports and suggestions for SoftMaker eM Client Professional 4 for Windows.
mlstomer
Post by mlstomer » Wed May 30, 2012 6:23 pm
Hello,
I notice that the software uses a very huge amount of memory and cpu usage which causes the program to hang for a long time becoming non-responsive.
It also takes a long time to search folders.
Not sure if there is a way to get the program to be quicker and not use so much memory.
Your thoughts would be appreciated.
Re: eM Client Uses A Huge Amount of Memory
Post by sven-l » Thu May 31, 2012 8:33 am
I will refer this a s a suggestion for future versions (to improve the performance) to the developers.
Post by martin-k » Thu May 31, 2012 11:43 am
I don't think it is normal that eM Client uses a huge amount of memory. How much is it? Can you please check with the Task Manager and report back?
mlstomer
Post by mlstomer » Thu May 31, 2012 7:13 pm
Thank you,
It fluctuates from 153MB to 55MB, it is actually the largest resource program I am running in Task Manager.
Post by sven-l » Fri Jun 01, 2012 9:32 am
I will refer this to the developers. Are you working with Windows 7? How many accounts do you have set? The more accounts you have, the more amount of memory and cpu usage is needed, but 153 MB is not too much. Also one question - are you downloading your messages for offline use or not? And what protocol do you use, IMAP or POP?
mlstomer
Post by mlstomer » Fri Jun 01, 2012 6:24 pm
In reply to your questions:
Yes windows 7
13 accounts
no not offline use
POP3
I also notice that when you have a lot of RE Messages say with at least 10+ e.g. RE (10) it uses at least 153MB, you have to create a new message and like start over with messages instead of RE to bring the resources down.
Thank you.
Post by sven-l » Mon Jun 04, 2012 1:02 pm
Thank you! I informed the developers.
Post by sven-l » Tue Jun 05, 2012 8:03 am
I wrote you an PM.
Return to “SoftMaker eM Client Professional 4 for Windows”
