Attempting simple macro for TextMaker
Post your questions, bug reports and suggestions here for BasicMaker 2012 for Windows.
Mercury
Post by Mercury » Wed Feb 29, 2012 1:13 am
Hello,
I'm trying to complete a simple macro that inserts a footnote and customizes how it displays. My macro simply sends a bunch of keys to TextMaker. However, the SendKeys statement does not seem to send the keys to TextMaker. It does not generate an error, it just doesn't do anything.
For example, the simplified script below will display the dialog box saying the macro completed without inserting the text "hello" into TextMaker. Am I doing something wrong?
Code: Select all
Sub Main
	AppTextMaker
	SendKeys "hello", True
	MsgBox "All done!"
End Sub
Edit: I tried the example program in the help file for the SendKeys statement that starts Calculator and sends it commands, and it also doesn't work. The Calculator starts, but none of the SendKeys statements do anything. I'm running on Windows 7 64-bit.
Also, how do I define a keyboard shortcut for a script once I've written it? The only way I can see to run a script is by using the Tools > Run Script menu command and then navigating to find the script. It defeats the purpose of automation if I have to do that every time! :)
Re: Attempting simple macro for TextMaker
Post by sven-l » Wed Feb 29, 2012 8:28 am
I referred your problem to the developers and will inform you here as soon as I have more information.
Post by sven-l » Wed Feb 29, 2012 9:02 am
Sendkeys doesn't work under Windows 7. the developers are working on a fix for this problem. You can attach the script to a user defined button (Basicmaker /s script.bas), then you can define a hotkey for it.
Mercury
Post by Mercury » Wed Feb 29, 2012 11:09 am
Thanks for the quick assistance, Sven. That's too bad -- hope it's fixed soon.
Return to “BasicMaker 2012 for Windows”
