Internal format for SoftMaker .doc files of XP/2003 type
Post your questions, bug reports and suggestions here for TextMaker 2012 and TextMaker Viewer 2012 for Windows.
dhlytle
Postby dhlytle » Mon May 29, 2017 3:54 am
I was having problems with search engines finding text in SoftMaker generated files saved in *.doc format. (version XP/2003)
Viewing the files with an editor, I saw a "00" character between each actual text character.
Similar documents created by MS Word 2000 did not produce that format, but read the Softmaker files without a problem.
Am I doing something the cause the creation of the added "00" characters?
I am attaching a simple example.
Operating system is Win XP.
(Yes, I know it is obsolete. I have an Win10 computer in my basement going though its shake-down cruise.)
I had some problems when I first tried to install the Softmaker products some months ago.
Thanks..
Testdoc.doc
(12.5 KiB) Downloaded 49 times
Re: Internal format for SoftMaker .doc files of XP/2003 type
Postby sven-l » Tue May 30, 2017 8:24 am
Was the attached sample file created with TextMaker? The Windows 10 file explorer shows the content properly.
Postby martin-k » Tue May 30, 2017 8:57 am
The 0 bytes come from the fact that we always save text as Unicode in .doc format. Microsoft Word stores either the old ANSI format or Unicode, so you sometimes see the 0 bytes and sometimes not.
Return to “TextMaker 2012 for Windows”
Who is online
Users browsing this forum: No registered users and 3 guests
