Problem under PortableApps environment
Post bug reports and suggestions here for SoftMaker eM Client 3.5 for Windows.
jdaughtryrcn
Post by jdaughtryrcn » Thu Nov 17, 2011 5:20 pm
In the portableapps.com framework, the launcher expects the executables to live in the primary application folder. TextMaker.exe et al already do, but the beta eM Client is in a sub-folder. Will it be elevated to the main folder in the final release? If not, can there be a launcher program in the main folder that points to the actual client in the sub-folder?
http://www.linkedin.com/in/JimDaughtry
Re: Problem under PortableApps environment
Post by sven-l » Fri Nov 18, 2011 10:09 am
I referred your question to the developers.
Post by sven-l » Fri Nov 18, 2011 10:51 am
Here is an answer from the developers:
Even though it is possible, portable usage of eM Client is currently not officialy supported.
In older version we had a support for U3 technology, but because of little demand
and popularity of this technology we dropped its support. Furthermore we don't have
a control of directory structure of binaries.
We may consider support for some of the newer portable technologies. This is on the agenda for the future.
jdaughtryrcn
Post by jdaughtryrcn » Sun Nov 20, 2011 2:53 am
I have found that moving the eM Client folder up one level appears to achieve the result I was looking for. There are other problems with running portable, but it is a step in the right direction.
Return to “Beta: SoftMaker eM Client for Windows”
