Failure to underline typos
Post bug reports and suggestions here for the beta version of TextMaker 2012 for Windows.
noteven47
Post by noteven47 » Fri Nov 18, 2011 12:06 am
Even though I enable background spelling check and tick the box in Tools/Options/Language, typos are not underlined in red (even after restarting Textmaker). UK English.
Re: Failure to underline typos
Post by martin-k » Fri Nov 18, 2011 9:23 am
Please check which language the affected portion of text is formatted in. This is displayed in the status bar.
(Even after setting Tools/Options/Language, you can still have text that is formatted in another language. What you set in Tools/Options/Language is just the "fallback language" that is used when your text is formatted in no specific language).
noteven47
Post by noteven47 » Fri Nov 18, 2011 12:39 pm
Status Bar says English (UK).
Spell check works ok when I request it but still no red underlining as I type.
Post by martin-k » Fri Nov 18, 2011 1:13 pm
Go to Tools, Options, Language and make sure that the checkbox "Underline typos in red" and the radio button "Background spell-checking" are checked.
Return to “Beta: TextMaker 2012 for Windows”
